Pilot.ie Now Stocking Aircraft Fuel Testers
A reliable fuel tester is one of the simplest yet most important tools a pilot can carry. Water, debris or other contaminants in an aircraft’s fuel system can cause serious issues if left unchecked, which is why pre-flight fuel sampling is such a vital part of good airmanship.
Pilot.ie is pleased to announce that we are now stocking the ASA Aircraft Fuel Tester. This practical tester is designed to make fuel sampling both quick and dependable:
  • Fits all quick-drain valves and comes with an adapter for recessed drains, making it suitable for almost every aircraft type.
  • The transparent cylinder is 6 inches long, allowing for a clear visual check of fuel samples.
  • Octane colour-coding is moulded into the side of the cylinder, making it easy to identify different fuels.
  • Includes a screwdriver blade with both Phillips and slotted heads – handy for quick adjustments during pre-flight checks.
By using this tester, pilots can easily check fuel for water contamination or debris, ensuring peace of mind before every departure. Compact and lightweight, it fits neatly into any flight bag and is built to withstand regular use. At just €13.50, the ASA Aircraft Fuel Tester is an affordable way to add an extra layer of safety to your pre-flight routine.
The tester is now available to order directly from Pilot.ie
Jenny Jacobs
